25-05-2018 06:05 PM - last edited 25-05-2018 09:07 PM
Hi,
i have a Samsung UE40C6200 TV with Software Version T-VAL6DEUC-1017.0.
The TV is connected with an HDMI to a Teufel DecoderStation 7. I'm not quite sure which version of HDMI cable it is. It only says: "Highspeed with Ethernet"
I want to receive the sound from the TV on the DecoderStation with the ARC. So i enabled the CEC and ARC option on the DecoderStation. On the TV I also enabled CEC and set the "Receiver" option to "on" (Tools -> Anynet+ (HDMI-CEC) -> Receiver)
On the DecoderStation the Input is automatically switching to ARC, but I don't hear anything.
I have also tested another HDMI cable without success. With my remote control of the TV i can change the volume of the DecoderStation.
Can someone help?
Thanks!
25-11-2022 12:37 PM
I’m having the exact same issue. I run the tests and sounds works, but when switching to any source on my receiver, the video shows but no sound. Were you able to find a solution?
