20-08-2024 03:39 PM
20-08-2024 04:08 PM - last edited 20-08-2024 04:09 PM
@T82920b: To use Smart View, your Tab S7 and TV must be connected to the same Wi-Fi network, and cannot screen mirror via Bluetooth. If both devices are on the same Wi-Fi network, then you may need to enable Screen mirroring on your TV, depending on the model. For further details, please refer to the user manual.
To screen mirror from your tablet to the TV, swipe from the top of the screen to the bottom, than again to enlarge the Quick Panel > Smart View (located towards the bottom of the screen on Android 14) > Select your TV from the list of available devices, then follow the on-screen prompts.
20-08-2024 05:46 PM
@T82920b Sometimes there can be an issue if Bluetooth is activated at the same time. If after following the instructions you still have a problem with Smart view,I would suggest rebooting both the Tv and the tablet before trying again.
30-10-2024 12:26 PM
The only fix I've found for this issue is to reset network settings on the phone or tablet.
