Multi-Audio Output not available
(Topic created on: 25-03-2018 03:50 AM)
guionbajo
Hi, i have a tv model UN55MU7000 and a soundbar HW-J250 conected via bluetooth. I can select the soundbar or the speakers in the tv, but not both of them.
In Menu > System > Accessibility > Multi-output Audio is greyed out. I can not select it.
How can i solve this? thanks.
57 REPLIES 57
Maverick101
The only way I could get the multi-output to show up, was by using the TV speakers and a Bluetooth device. Such as headphones or speakers. But it will shut off your soundbar. If you read my above posts, I have not found a workaround yet to use my sound bar and a b.t. device at the same time.
MarianS
I bought a Sony bluetooth headset just to do an experiment. After pairing the headphones with the Samsung TV, "multi audio output" turn black. After that turn on soundbar on optical cable. Surprise, the sound is heard simultaneously in the optical soundbar, Bluetooth headphones and TV speakers. All 3 simultaneously. If I turn off headphones, turn gray again. Why bluetooth headphones turn "multi audio output" from gray to black, but Bluetooth soundbar does not? I just want to use soundbar and TV speakers simultaneously. I hate Samsung firmware so much... sucks.
Let's both throw Samsung TVs out the window ... at the same time.
Cd3560
Tks Stewie , worked perfect . Any ideas on stopping pop up connection message when hearing ***** not needed
RNTeare
Thanks, thanks, thanks.
Stewie, your method worked perfectly.  I have an 8000 series TV.  I paired my Jabra headphone (see Wirecutter) and got the sound to come out of the headphones only.  Then, your solution:  I changed fthe "Source" to "TV," went back to the multi-ouput sound button and made it "on."   Then, I went back and made my "Source"  "Directv" again.   (I have the Directv recorder.)  I changed the audio output back to "TV speaker."  Now, when I turn on the TV sound comes out of the speakers and a little window appears in the upper right asking me if I want to "connect" my headphones.  I do.  I can alter the volume of both outputs independently.
So, by temporarily cutting off my Directv Box as the "Source,"  the "multi-output sound" option became avaailable.   The rest makes all logical sense.  Thanks.
Reader:  please follow Stewie's concrete instructions.  They are just great!
My hearing-impaired body is now in sync with my soul.  Heaven.
Big complaint:  The Samsung chatroom was useless, was uninformed.  They need to pay their operators more.
Small complaint:   I had a hard time finding you, Stewie.  However, when I wanted to find you again I googled "Stewie Griffin Apprentice" I found your excellent instructions.
RNTeare
PhilO2
I am using a BOSE soundbar. I first paired up a Bluetooth speaker and the selected Multi Audio. Then, IMPORTANT, I connected the Bose and the TV via Optical Cable, and set the BOSE TV source to Optical. Make sure there are no HDMI connections to your soundbar, only Optical. Both TV and Soundbar speakers work perfectly at the same time.
NDev
Will a HDMI soundbar and an Optical-Out (Toslink) device work at the same time on a 8000 series TV?
I dont need the TV speaker or bluetooth devices at all.  Just HDMI and Optical.
Redhot35
This works
R131
Solved my similar problem today after just buying a new Samsung crystal UHD series 8 TV.. (UA43TU800OS)
Used my old TV remote which had a menu button.
Many thanks Stewie
Tim104
Hi,
Followed Stewie's suggestion and managed to get 'Multi-output' enabled, but as soon as I re-connect my Sonos Beam soundbar to HDMI (arc) Multi-output gets disabled. Anybody been able to sort this out or should I give up?
Thanks,
Tim
Radiorandy
I have a QN55Q6DTAF  and had the same issue with not turning on TV speakers and Bluetooth at the same.  I called tech support and they told me it could be done. Support is useless.  This is what I did,  connected my bluetooth headset, settings , general, accessibility, Multi-output (now not grayed out) turned on and now have audio on TV speakers and headphones
Randy
