Sound output optical UE48H6700
(Topic created on: 26-03-2018 10:58 AM)
Andor
Hello,
I have a smart tv wich have a optical out. I plugged in a nad 356BEE with also a DAC with optical option. After done, i have to push the volumeknob on my amp sky high for any good sound. When i put a blu ray or something else on the optical on the amp, then not.
I have in the normal menu select to not use tv speakers. What do i have to change in de tv to get a normal volume? Something in the expert menu ???
kind regards.
0 REPLIES 0
