Lost HD Channels on UE49ku6670
(Topic created on: 26-08-2017 12:06 PM)
Rakesh72
As the heading suggests my HD channels have dissapeared, apart from QVC HD.
I have tried retuning and have reset the tv and gone through the set-up process again.
I have checked the signal information and get the following on the QVC HD Channel (111)QVC ch-111.jpg
Gratfeul for any suggestions on how I can fix this
2 REPLIES 2
KellyM
Helping Hand
Hey @Rakesh72,
The signal information doesn't look too great. Have you tried a different aerial cable or aerial connection point with the TV?
MONTY38RAY
Hi had same problem with same tv just go to setting and retune all channels and you should find they all return
