LED tv white screen
(Topic created on: 02-08-2018 05:44 PM)
AHM
My ue40f8000sxxtu started to show a white screen and after I turned it off for  a while it came back on ok.
What could be the problem?
1 REPLY 1
JAMES4578
Samsung Members Star ★★
I would suggest a screen test ,  Support-Self Diagnosis-Picture Test.   However if that is ok then monitor it for now but if errors show up at any point could indicate a fault with Board/Panel.     In this instance would be best to Contact Samsung  as repair will likely be necessary, you could use Remote Support or call on 0330 726 7864.
