My samsung tv started flashing white and the screen went white can anyone help
(Topic created on: 09-02-2025 07:02 PM)
logan_s
Here's a photo
8 REPLIES 8
Ginga_p
Hotshot
Have you run a hdmi test in the settings menu
G G
logan_s
I could try that but it starts to flash a bright white then goes like that
Ginga_p
Hotshot
It does this as soon as you turn the tv on then. What are you plugging the tv into via hdmi
G G
logan_s
I'm using it for an Xbox
Ginga_p
Hotshot
Can you not get into the settings menu at all.
G G
logan_s
Within a couple seconds of the tv turning it will do it again so i can't assess the settings menu
Ginga_p
Hotshot
Sounds like either the xbox resolution is set to high. Try turning it down to 1080p
G G
logan_s
Nevermined we found out the colour had gone thanks for your holelp though
