09-12-2019 10:58 PM - last edited 10-12-2019 07:24 PM
I have some severe clipping, cutting out, choppy, glitchy, stuttering (whatever is the correct term) audio.
It happens for a millisecond every other second or so. It feels that it happens more often when there are audio intense moments, but it could also be that it's just more noticeable at those moments.
It happens on both HDMI channels (Apple TV and XBOX), as well as DTV (which I never watch, so that's not really an issue, but could help determining the problem).
The apps on Samsung works better, but after a while the clipping sound appears. On the apps it occurs sometimes and sometimes not, compared to the Apple TV and XBOX where it happens all the time steadily.
When I connect the optical cable to my XBOX everything sounds perfect and there is no clipping whatsoever.
Also analogue works perfectly with the amp.
All the suggestions I've read mostly focused on changing the Digital Output Audio Format to PCM, which I've tried with no luck.
I've tried factory resetting the TV which didn't do anything.
The manual for my amp says:
The digital inputs are capable of handling up to 24bit / 192 kHz audio signal in PCM-format. check your source signal type to make sure it is in the right format.
Are there any settings I'm missing on my TV to set this up properly? Does 24bit / 192kHz mean anything that I should change in the setup?
Here is my setup:
TV: The Frame 2019 49" (QE49LS03RAU) – 2 months old
Amp: NAD Amp1 (NADAMP1BK) connected via the optical input (D1 for TV use) with a new optical cable (ARGCL1OPT1,0) – both bought 1 week ago
Stereo system 2:1
HDMI 1: Apple TV4 connected with new Premium HDMI cable from Deltaco
I've tried all the different audio settings (Stereo / Dolby Digital, and forcing 16bit) which doesn't change anything
HDMI 2: XBOX One S connected with the in-the-box HDMI cable – 2 weeks old
Tried Stereo Uncompressed and Bitstream, neither changed anything.
Worth noting is that the TV don't recognize my amp correctly, it instead sets it up as a Denon.
When it doesn't want to set the amp up and I manually have to say which it is I can choose Nad Amp1, but the remote won't work then and it didn't have any any other affect on the audio.
14-01-2021 02:36 PM
Hi everybody,
Same problem here!
I own a Samsung UE40KU6470 and NAD Amp 1.
I am realy satisfied with this amp. It has a great phono input and in combination with my Mission 751 Freedom speakers is a great combination. Now the optical connection with the Samsung is a BIG let down. Tried new toslink cabels and all kind of different settings. Even tried to put the tv on ‘stereo’ instead of ‘Dolby digital’ and nothing worked. Tried my amp with the tv of my neighbour (Panasonic) and that worked fine! So please Samsung, can you fix this with a firmware update? I will try a letter to NAD too......
15-01-2021 12:45 PM
Dante was absolutely right about the inscription in the Gate of Hell: "You who enter abandon all hope."
16-01-2021 10:26 AM
The Argon Nano DAC did the trick for me, as it has done for at least one other person in this thread.
I had an older, almost similar, Argon DAC that worked well with an older, LED Samsung TV, but it didn't work with my new 43" Frame TV. It had all the symptoms described in this topic lead. But with the Nano DAC (approx €70), I have been running smoothly for two days now ... hoping that this post doesn't jinx it 🙂 It is such a relief, rather than having to pack the TV back down and arm-wrestle the vendor for a return.
17-01-2021 07:44 AM
Joining the team. I've the the 2019 Samsung Frame TV with One Connect box connected via optical / Toslink to a Peachtree Audio novaPre pre-amp with ESS Sabre DAC. I'm experiencing the same frustrating audio skips.
It seems to happen the most in the YouTube App, and doesn't seem to happen in the Spotify app. I'm emailing the Peachtree team now, will share what I learn!
21-01-2021 06:20 PM - last edited 12-02-2025 10:33 AM
I had a similar issue with a Samsung 49" Q7R (2017 model) TV and Cambridge Audio CXA61 amplifier that I received a few days before.
I contacted with support of Cambridge Audio as it was proposed in the following link:
CXA61/CXA81 - TOSLINK Optical Input and TV Issue – Cambridge Audio Support
They have send me an RS232 cable in order to make a firmware update along with instructions.
But when I came home, I found that actually my CXA61 has already the fix. It just needs to be activated through setup menu in order to do so:
I do not know why there is no documentation at least for trying to see if you already have the fix.
The same steps can be followed for Cambridge Audio CXA81.
The support was quite fast and I am glad that there are some ways to solve such issues without even needing to send the product in order to be fixed.
EDIT: The solution now is included in their official manual for all amplifiers (CXA61, CXA81, CXA81 Mk II). The link above is no longer working, but the following is now the reference:
05-04-2021 09:39 PM
Thanks, I just bought a CXA81, and I was suffering from the same sound issue with my Q90 TV. I have tried this setup, apparently the amp was already patched.
15-08-2021 03:36 PM
I also have the clipping as mentioned in this thread. It occurs via HDMI-arc and the optical toslink. The digital output is not usable for this TV.
I have a frame 2021 together with a NAD D3045. I also tried with two other amplifiers, and the problem remained, so this is not a compatibility issue.
I made a recording of the audio output:
https://www.dropbox.com/s/w3ddh4fqwvgfxw7/SamsungFrame2021_clipping_HDMIarc.mp3?dl=0
04-11-2021 06:06 PM
Same issue here with Q9FN and Audiolab 6000A Play (has a Sabre DAC). Firmware offers PLL wide on OPT2, but my dirt cheap set-top box has an optical connector, so went for that one and audio is excellent now. Bad Samsung, really bad.
06-12-2021 08:20 PM - last edited 06-12-2021 08:27 PM
Same issue with two Samsung the frames here.
The frame 2017 has audio clipping/drops only if tv signal is the source. Apps and hdmi sources (like game consoles) works fine.
The frame 2021 has audio clipping/drops regardless of the source.
Audio issues are by optical and hdmi-arc connection. Do not buy audio hdmi-arc audio extractors. It will be useless with this issues.
Many thanks for this thread. Now I know what is the source of the issue.
I have relatively old DAC (Pioneer N50a) with no manufacturer support. No chance for any firmware update for it. Maybe is it possible to buy some kind of device to purify one connect box optical signal and put it between Samsung and DAC? What you think guys?
My DAC gives me very good sound. I don’t want to change it for Fiio or something similar. Now I use Logitech Bluetooth but sound quality is rather poor.
08-12-2021 01:01 PM
Hi,
Got almost the exact same setup as Monographia (initial post) with a Frame 55" 2021 and a NAD AMP 1.
And I've got the same issue with glitching sound. Thought I'd just share what I've tried and the results.
1. Tried with Bluetooth (unsuccessful):
As the NAD AMP does offer a Bluetooth connection, I figured it was worth a try as am not so concerned with the quality of my TV sound. Turns out the NAD AMP actually responds to signals from the Samsung remote control as a "smart feature" they've added... Only problem is that a volume up/down press from the Samsung remote nudges the volume on the amp to jump in steps of random big numbers. Makes it close to unusable. Going from level 0 to level 74 with one button press!
2. Trying a cheap "nano" DAC (successfull):
So I went to a cheap Norwegian store and got this mini DAC for a good price (https://www.kjell.com/no/produkter/lyd-og-bilde/kabler-og-adaptere/rca/signalomformer/dac-lydomforme...). It works like a charm, no glitches are detected in the past week. The amplifier actually still turns on when detecting signals to its Line-in port too, so that's a bonus I didn't dare to hope for. The sound is not too bad in my ears, and the most important thing for me now is that it is at least even and smooth. Didn't imagine that it would be a problem in the first place, but here we are ranting in a forum.
Strange thing is that I had a Samsung Smart TV with a similar OneConnect hub from 2017 that worked like a charm with the same setup. Which just makes the whole thing even more annoying.
Anyway, thanks to you (Monographia) for enlightening the issue and to the guys advising to try a cheap DAC!
