19-01-2024 10:59 AM
- Mute
- Highlight
Hello,
I just bought a Samsung TV #QE50QN92C Neo Qled 2023.
I don't know why there's no analog output on the TV, so I connect my speakers in Optical via the following assembly:
TV --> toslink --> Digital-to-analog converter (Swisssonic) --> RCA/XLR --> Active speakers (amplified, Adam T7V) .
The sound works perfectly and I've been able to set my parameters so that the default sound only comes out of the optical output unless I plug in my Bluetooth headphones...
The big problem is that I have no control over the output volume! It's always on full blast!
Neither from the remote control (pushing up or down the volume button) I get a message "Optical output" instead of the volume control. Nor from the menus. When the sound comes out directly from my TV, it works perfectly, no problem.
How can I solve this problem and why can't I adjust the volume of the optical output?
Thank you for your answers.
Kind regards, A.
19-01-2024 11:10 AM
- Mute
- Highlight
Use HDMI EArc from TV to speakers if they have hdmi connection.
19-01-2024 11:44 AM - last edited 19-01-2024 12:03 PM
- Mute
- Highlight
Hello,
Thank you for the reply 😁
But unfortunately there is no HDMI EArc input, only TosLink S-PDIF or other analog (Jack TRS, XLR...).
I'm more interessting to understand how to fix volume control for the optical output of such TV before buying new hardware to adapt to other output such as HDMI arc.
Thanks !
19-01-2024 10:11 PM
- Mute
- Highlight
31-05-2024 05:13 AM
- Mute
- Highlight
Try the method in this video.
