How do I disable PIP on Samsung QE43Q60AAuxxu tv
(Topic created on: 21-10-2022 11:52 AM)
geetee1
When I cast from a Galaxy A tablet I get a split screen on the Tv. How can i disable this?
I cannot find it on the manual.
Thanks for any help.
5 REPLIES 5
TessM
Mastermind
Hi @geetee1 ,
I would love to help you with this. Can you please confirm what method are you using to cast the Tab content? Are you casting from an app or are you casting the whole screen?
geetee1
Hi TessM.
Thanks for the reply
I am casting the whole screen from the tablet, but on the TV screen, the cast is on one side of the screen and the current TV programme is on the other.
TessM
Mastermind
It's my pleasure! Thanks for confirming that. I feel that this page may help you understand how this feature works and turn this off: https://www.samsung.com/us/support/answer/ANS00086522/
geetee1
Hi TessM. Thank you for sending that.
Unfortunately, I don't appear to have the autorun multiview feature. The only autoruns seem to be the hub, and the last app.
I do have multiview itself though, so is there another way of disabling?
geetee1
Hi TessM. Are you still there? If so, could you answer my question at the end of the thread, please.
