Help samsung UE49KU6400 fades and turns off
(Topic created on: 25-11-2018 11:23 AM)
Russellhmfc
Hi I would greatly appreciate some help guys, Ive had this tv just over a year and recently it has started fading then turning itself off then on again which has got worse and now just goesinto a boot loop. Ive tried turning of anynet and resetting which was fine for a bit and now it seems to work fine for my cable box but as soon as I plug in my PS4 pro it fades and boot loops.
Please help.
1 REPLY 1
AndrewL
@Russellhmfc: Have you tried connecting your PS4 Pro to each HDMI port to troubleshoot the issue? It may also be worth playing with the video/picture settings on your PS4 such as reducing the resolution to see if this helps. If not then I recommend contacting the Samsung AV Team on 0330 726 7864 where an advisor will be able to assist you further.
