Go to solution Solved
Freeview on QE50QN94A
(Topic created on: 04-10-2023 05:18 PM)
tiptonian
I have TV model QE50QN94A, about 2 years old, but I'm only just trying to set it up for Freeview. However although the TV has 2 x F connectors for satellite, it is missing the Coax input for a terrestial aerial.
Is this normal for this TV or would it have been a manufacturing omission on my set and if so is there anything I can do about it at this point please?
AndrewL
@tiptonian: From your photo, it does look as though the terrestrial aerial input is missing at the bottom of the ports. Where did you purchase the TV from?
2 REPLIES 2
AndrewL
tiptonian
Thanks for reponse. Bought from Currys over 2 years ago. The reason I'm only looking at it now is due to having Sky but I had wondered about setting up Freeview to watch on those rare occasions that Sky is recording 2 programs and I want to watch something else. I've decided it's likely to be more trouble than its worth to try and rectify it.
