04-10-2023 02:46 PM
04-10-2023 04:46 PM
Hi @Herbsman A flashing red light generally indicates a problem with internal component or power. check you have the latest firmware on Samsung support? Are your connections secure,could try disconnecting/reconnecting the the cables, can you try another socket to see if that makes any difference. If by any chance you are using a surge protector sometimes there can be an issue there. See further information here but may well need further investigation. https://www.samsung.com/uk/support/tv-audio-video/my-tv-wont-turn-on/
07-10-2023 08:28 AM
It turns out that these issues are shorting pixel circuits within the screen and it can only be fixed by searching for the shorted circuit and masking it with tape which resolves issue but with minor screen imperfections. Seems to happen just after 2 years. Why Samsung are not being forced to have a recall on these screens is beyond me so we will never buy Samsung again. They need to own up and make it right. 3 members of my family Ali e have had this issue and the tvs are un fixable.
