05-10-2020 09:58 AM - last edited 05-10-2020 09:59 AM ) in
TVHi,
I'm considering buying a frame TV and read you can upload your own images to display in art mode. I was wondering if it's also possible to upload video or gif so you could play animated loops as art works? And would these be able to loop seamlessly?
Thanks!
Solved! Go to Solution.
05-10-2020 03:45 PM in
TV05-10-2020 10:23 AM in
TV05-10-2020 12:01 PM in
TVThanks you!
05-10-2020 03:37 PM in
TV05-10-2020 03:45 PM in
TV05-10-2020 04:46 PM in
TVThanks to you both!
14-10-2020 04:15 PM in
TVYou can only make a collage if you have an iPhone and the app. So no its not user friendly for uploading and framing your own pics. Needs a simple software update to allow random and play direct from a USB stick too.
22-11-2020 09:19 AM in
TVyou can upload pictures via usb plugged in
28-11-2020 05:45 PM in
TVBe careful with the art mode of the Frame. There a several software problems with this mode. With my Frame 43" 2020 the art mode isn't working anymore and I am not the only one with this problem. Search the web before buying a Samsung Frame.
03-09-2021 09:12 AM in
TVCan you, please take time to upload how to do that, not been able to with mine but that would be helpful as I only have 3 photos on ours due to memory. Play direct means play off the USB stick, not transfer the photo to the limited TV memory
