Eurosport player
(Topic created on: 15-10-2019 07:13 PM)
Frederik78
Some days back the eurosport player stopped working on my ue55ks8005 with software t-jzmdeuc-1241.5, bt-s. Now when i open the app it tells me that i should download the newest version of the app but when looking for that in apps there is no newer version. It seems to have happened after the last software update. What to do?
20 REPLIES 20
CarlH
Hi @Frederik78. As your software is up to date, can you try resetting the Smart Hub? To do this go to Menu > Smart Hub > Reset Smart Hub. At this point you will be prompted to enter a PIN. If you have not set one up this will be 0000. Let me know how you get on with this.
Frederik78
ive tried that and it did not make a difference.
frederik
CarlH
It might be best to get in touch with the app developer in that case, @Frederik78
DavidS3
I have the same issue and contacted Samsung support. Went through the same steps and still didn't work. This is down to Eurosport. I have contacted them as I cannot also stream from my iPhone or iPad to Apple TV. I have given them a month to sort out the issues then will be asking for a refund.
DavidS3
Ca
N Samsung take the Eurosport player app off their system till an update is provided by Eurosport
RpBP2
Pathfinder
Perfect let a couple of days to check again and refeedback thread :thumbs-up-sign-emoji-modifier-fitzpatrick-type:
DavidS3
Eurosport app for Samsung tv app still not working but Eurosport have agreed to refund my subscription
Sebastian_C
For me it work on AppleTv and iPad.. not on Samsung TV however, Eurosport specifically says that the app only works with: Samsung TV with Tizen OS only 3.0+
You can find all supported devices here: https://help.eurosport.com/hc/en-gb/articles/360009615660-Supported-devices
DavidS3
That's right. Mine is UE49KU6100 and is Tizen 1.0. Considering Amazon Fire tv stick
