24-09-2021 03:50 PM in
TVHi,
Ive just bought a new Samsung 65TU7020 TV but it doesnt see my 5GHz internet connection.
The TVs software is up to date
Does this TV support 5GHz internet?
24-09-2021 04:10 PM in
TVHey @Anonymous User ,
I have had a look at this and in order to check if your TV supports this, you will need to check the connectivity settings. if your Samsung TV has 802.11a, 802.11n, or 802.11ac configuration, it will support 5GHz Wi-Fi.
24-09-2021 04:24 PM in
TVThanks TessM,
Where can i check if my TV has 802.11a, 802.11n, or 802.11ac?
Is it in the settings?
24-09-2021 05:27 PM in
TVYou are very welcome! Oh, my bad! You can check this from the TV Settings> General> Network.
Have you tried to set your router to display the bands with separate names for every band and see if that one appears on your TV?
24-09-2021 10:34 PM in
TVNo i couldnt find the settings for 802.11a, 802.11n, or 802.11ac
I have labelled my SSID channels as 2.4Ghz & 5Ghz
I can use 2.4Ghz but all my other devices are on 5Ghz
