Go to solution Solved
Does my TV have timeshift?
(Topic created on: 02-07-2023 07:12 PM)
TaGa11
I would like to know if I have TimeShift fuction on my QE55Q67BAUXXH smart TV? Thanks in advance.
LukeB2
Helping Hand
It does indeed, @TaGa11 ! You can view the E-manual to learn more and this is located on page 122. You can view this via this link: https://downloadcenter.samsung.com/content/UM/202301/20230127170848354/BN81-22795C-580_EM_OSNDVBEUB_...
Hope this helps!
9 REPLIES 9
LukeB2
Helping Hand
Hope this helps!
TaGa11
Thanks for reply. I tried it with connecting an external hdd and pendrive but non of them worked. What can be the solution? How can I check if my drive is OK for this function? Eg. if system can read the drive? Are you sure my serial number is OK for timeshift? Thank you in advance.
AndrewL
@TaGa11: For a USB device for recording, it is recommended to use a USB hard disk that supports USB 2.0 or later and 5,400 rpm or higher. However, RAID-type USB hard drives and memory sticks are not supported. For further details, please take a look at page 179 of the user manual via the link provided above.
TaGa11
Unfortunately it is still not working. Could you please check the recording possibility with my TV's detailed data?
MN : QE55Q67BAUXXH
PD : 01/17/2023
SN : 0J8W3HDTB01252B
FW : T-NKLBDEUC-1520.7
FC : SWU-OU_T-NKLBDEUC_1520_230721
MI : T-NKLBDEUC
LS : EU
DI : 2DCKEHBTVCFIO
MA : D0C24E780564
SC : 40401_AA1AC1AE1_IM10_AA62AC45AD13.7AE13.8AF0TB0BA46CA73DA0HB8IB73IC239IMG_20231026_102850.jpg
TaGa11
Additionaly my HDD data:
WD Green SATA SSD 240 GB (WDS240G2G0A)
It is formeted to NTFS fileformat.
pergy
Hi,
same thing happens to me in Hungary. Based on what i read other forums (https://www.avsforum.com/posts/62799117/) I believe that the feature is locked in certain countries in CE Europe. I guess Hungary is one of them. I hope some techie can confirm this or provide a solution.
TaGa11
Hi Pergy,
Do you maybe have new idea? Thanks in advance.
pergy
I have read elsewhere that you can try to change the region registered with the TV in service mode. However, it obviously can be dangerous
TaGa11
Do you know maybe where can I find any description about it? I mean the process of enter service mode. Thanks
