Delete transponders
(Topic created on: 11-07-2021 03:58 PM)
unhappy user
It is strange.
Shortly: inserted a new card, made a search, 650 channels on list (it is crazy), of course I had to add new transponders because no predefined in TV, +100 more channels.
 I am contacted the local Samsung support in Slovakia regarding transponder issues. "why I can´t delete transponders from TV, why I can only add?" The answer was that you can delete the not needed channels by external program. So, it is true, but how I do know, which one is the working (5 Eurosport, 10 nickelodeon, 7 NAt geo, etc) channel? Answer was I can´t help you.
My 15y old external no-name receiver was able to do it.
The guy from support promised to send the issue to technicians. You can think what happen.
Right........... NOTHING.
3 REPLIES 3
GER8S
Hello, same issue. After a blind scan, several "fake" transponder were automatically added. Did you find a solution?
unhappy user
Hi, no solution, even after contacting samsung support. They don't care customer after they sell a product. Today the right side of the screen stay black, LED's are go on (second time). For now no more repair and no more SAMSUNG. If you have a chance to return it, do not hesitate.
GER8S
hello. I'm sorry for your inconvenience: which TV set do you own?
About the deleting of transponders, do they remian in memory even if you perform a factory reset?
