11-07-2021 02:59 PM - last edited 11-07-2021 03:02 PM ) in
TVHi,
I am thinking of purchasing a 32" Frame for out kitchen but was put off by the fact that the cable on the 2020 model sounds like it was a lot thicker than other models in the range for some reason. I have been trying to find out if this has been addressed with the 2021 model or if the cable is the same as before. So far I have been unable to get an answer.
Also, I have seen that there have been connectivity problems between The Frame models and Sky mini boxes.
Does anyone have 2021 32" model and can comment on these areas please?
Thx,
Graham
23-10-2021 05:20 PM in
TVI've just bought a 2021 Frame 32 inch. It comes with a 2.5m grey cable which is 6mm diameter. I'm trying to source a longer (and ideally invisible) cable for it but so far haven't had any luck
4 weeks ago in
TVHello
did you manage to find an invisible cable for the 32inch frame tv? I just bought the tv and am gutted to see this ugly grey cable. How is it meant to look like a picture with that hanging down 🫤
4 weeks ago in
TVNo I didn't mate. In the end I gave up and went with a totally different TV because of this issue.
