16-10-2018 05:13 PM in
TVHi, I’m having problems with my Samsung TV showing the message “Check device - Recording and Timeshift are unavailable, Makre sure your external USB hrs drive is properly connected to the TV and try again”.
Nothing is connected to the USB drive, I don’t record or use Timeshift. I can’t change the channel, change my volume, access the TV guide nothing. I’ve turned the TV on and off at the mains but nothing. I can’t check if the TV software is up to date as I can’t get past the message. Does anyone know what I should do? It’s very frustrating.
16-10-2018 06:12 PM in
TV
