11-12-2019 09:27 PM
Hello,
Since my tv UE50RU7025KXXC updated to T-MSLDEUC-1335.0 cast/mirroring is not working on phones or pc.
Thanks for your help
Solved! Go to Solution.
16-05-2020 05:59 PM
Samsung team and owners,
I fixed the problem.
Please follow the below steps to clear all your connected devices from your Smart TV.
Menu
Settings
General
External Device Manager
Input Device Manager
Device Connect Manager
Device List ( In the Device list) I removed all connected devices and exited out of the menu. When I connected using Smart View on my S8+ and gave both your Smartphone and Smart TV permissions to connect. Both pairing numbers should match the Smart TV and Smart Phone. I did this with my Samsung 8 series 75 TV model number UN75RU8000FXZA. I was able to click on S8+ Smart View and connected to my Samsung TV without any issues.
Enjoy.
12-12-2019 11:13 AM
Hi @ValentinN. Are you using the Smart View app on your phone? Which model phone do you have and is the software up to date.
12-12-2019 11:19 AM - last edited 12-12-2019 11:21 AM
Hello,
It's not working using the app or using the native feature of my phone. I tested it with a Samsung s8+ and a honor view 10. It's also not working with my pc on Windows 10 with the native feature. All systems are UP to date
12-12-2019 11:23 AM
Thanks @ValentinN. Is the software up to date on your S8+? ^CH
12-12-2019 11:25 AM
16-05-2020 05:59 PM
Menu
Settings
General
Enjoy.
06-02-2025 09:42 AM - last edited 06-02-2025 09:49 AM
