Go to solution Solved
Can’t connect Bluetooth speaker to Tv
(Topic created on: 30-06-2021 06:50 PM)
EwanWhite3112
Hi there I got a Samsung ue43tu7020 last year and just treated myself to a Bluetooth speaker however I cannot connect the speaker to the tv or find any Bluetooth settings in the menus. Please help thanks you in advance
Pugs1957
SuperStar
6 REPLIES 6
Pugs1957
SuperStar
Try Settings > Sound > Sound Output > Bluetooth Speaker List and select your speaker which needs to be in pairing mode.
EwanWhite3112
Hi I’ve done that but the Bluetooth speaker list doesn’t show up as an option only tv and optical
Pugs1957
SuperStar
EwanWhite3112
Is there anything I can do to get the Bluetooth speaker to work with it
Pugs1957
SuperStar
You could purchase an adapter like one if those in this article https://www.tomsguide.com/uk/best-picks/best-bluetooth-TV-adapters
AndrewL
@EwanWhite3112: Can you try closing down any apps that you have open, if applicable, then checking Settings > Sound > Sound Output > Bluetooth Speaker List once again to see if the option is available for selection? If not, head to Home > Source > Connection Guide > Audio Device > Bluetooth to find further details on how to connect. Please be aware that you will be unable to connect a Bluetooth Speaker if you currently have audio devices connected via Settings > Sound > Wi-Fi Speaker Surround Setup.
