Go to solution Solved
BBC iPlayer not working on UE32ES5500K TV Smart Hub
(Topic created on: 05-08-2017 12:21 PM)
00bm00
For a few months BBC iPlayer has not working been working on our UE32ES5500K TV Smart Hub. If we click on the Button, it just goes to a black screen. 4OD, ITV and other services are working OK. It won't let me Uninstall the app, so I can't reinstall a new version. It says its on Version 2.02603. If I try and run it from the App Store screen, it still goes to a black screen. Any suggestions?
Go to solution
87 REPLIES 87
AntS
Hi all,
Updated official TV Support page link that has a little more info/clarification on the BBC iPlayer issue here: https://www.samsung.com/uk/support/tv-audio-video/bbc-iplayer-software-update/
Val15
Thanks for the information from dc25. Turned off the TV and did a factory reset as suggested. Works!
StephenD
Message for Samsung, all the BBC apps have stopped on the Samsung HT-E8200 Soundbar. I’ve tried the online update but states up to date. Please can you advise?
Markholtby
Hi
Many thanks for this information
After doing all the resets etc to no avail! I read your message tried it and guess what! It worked
RAYGG
i have a 2013 samsung smart tv modelo UE46F6500MODELO. Back in January i managed to uddate via usb the version 2127.0 and fabulous all app working better than ever. However end of Feb the bbciplayer stop working. Is there another update need or is the problem mre serious.
RAYGG
try update via usb the version 2127.0 find firmware update in Samsung web.
RAYGG
no its not its 2127
st122ee
I'm having the same problem, I click on bbc Iplayer, it loads then stops and kicks me off the app, then the whole TV is black with no sound, but the Samsung TV channels work. it does not correct its self untill I turn the TV off at the wall, process is repeated when I try to go back onto iplayer.
