17-05-2021 11:52 PM in
TV18-05-2021 04:20 AM in
TV
hello
as checked
Google Assistant Built-in N/A
Works With Alexa Yes (GB, FR, DE, IT, ES, AT, IE only)
please contact customer service if requires external voice assistant device
or we may have missed some settings
31-12-2021 10:22 PM in
TVHow do you connect this tv to Google assistant? The instructions are not clear
08-01-2022 08:02 PM in
TVHi
Did you found how to get voice control on your tv?
Support told anything?
02-05-2022 12:22 AM in
TVSame here. Bought from John Lewis this week, April 2022, which said on its website the TV comes with all of the above but it doesn't.
No "voice" option in settings. Anyone have any updates on this issue?
22-09-2022 04:15 PM in
TVVoice control is not built into this model but is possible via SmartThings and Google Assistant. Install and set up SmartThings. Add your TV. Go to the SmartThings home screen. Click the menu in the bottom right. Choose Voice Assistant. And then Choose Google Assistant and follow the instructions.
22-10-2022 05:19 PM in
TVLike everyone else I bought the TV because it said in the advertisement that it had built in Google and Alexa, which it doesn’t! Do you know if I buy an Amazon Fire Stick if that will allow me to search for different programmes etc? Samsung Smart Things just allows me to turn the TV on and off so is pretty much useless. I rang Samsung’s technical department but couldn’t get any sense out of them.
