Analogue audio output for the QN90B
(Topic created on: 09-11-2022 05:23 PM)
NMeelan
I've just bought the QN90B tv and have an analogue speaker system. I've noted that there is no headphone jack on the tv, which is how I connected my speaker system to my old tv. I need to find a way to get the audio from the tv to RCA cables to go into my amplifier.
I've seen numerous ways to get the audio to my speaker system using a digital to RCA converter. Can someone confirm the best way to do this? I've seen there is an optical to RCA converter, which also has a coaxial port. Basically, if I did get this converter, is an optical or coaxial cable best? And is there a coaxial output on this tv? Or is there a better way entirely than this converter?
Samsung support keep telling me to use HDMI to analogue instead but I'm finding a reliable converter for this hard to come by.
Many thanks for any help!
1 REPLY 1
Rg2by
I am in the same position. Have you found a solution yet? I was wondering whether a DAC converter with optical cable is ok, or the the more expensive one with HDMI Arc input?
