55ru8000: backlight bleeding and light through the corners
(Topic created on: 12-11-2019 11:44 AM)
OldLogan
Hello,
I have just bought a 55ru8000 smart tv and I have noticed a couple of issues.
Light is splitting from the four corners of my TV's frame. Is that normal for this model?
The second issue is about backlight bleeding. Small gray cones can be seen at the corners (especially the lower ones) only when looking at dark scenes. I read in the reviews that this model should suffer very little backlight bleeding...
Thank you!
7 REPLIES 7
SaudA
Troubleshooter
Hi @OldLogan
Can you try this hardware test: Menu > Support > Self Diagnosis > Picture test, and post the results here?
Jerry120
I have the same model & getting the same issue, bottom right corner is most noticeable in dark scenes. Picture test is useless because it's a bright picture and you can't notice the bleeding...
Did you manage to fix it somehow?
SaudA
Troubleshooter
Hi @Jerry120
Is this happening when using all apps/channels?
Do you have any external devices connected to the TV? If so, can you try disconnecting them and see if this makes a difference? Just want to rule this out.
Jerry120
all apps/channels
I will try tonight, only a PS4 & Chromecast is connected, surely that shouldn't cause the issues?
SaudA
Troubleshooter
Thanks, @Jerry120
It shouldn't really cause this, however, it is something that we need to rule out just in case.
Jerry120
it still does it without any external devices connected
CarloL
Hotshot
Thanks for confirming that. The best thing to do in this case would be to get in touch with the Samsung AudioVisual team. if necessary, an engineer will be sent out to you to check on the TV to understand the reason behind this issue. You can contact them here: 0333 000 0333.
