High battery and ram usage
(Topic created on: 13-08-2025 09:32 PM)
Robbie_R
Hotshot
Anyone else facing high battery drain and high ram usage? I know the battery always takes a dip when a big update is applied but its draining faster than even on the ui 7 beta.
7 REPLIES 7
NAMZY
Iv just come to the conclusion that Samsungs phones allwsys drain fast no matter what
Aldreno
Navigator
mkk7781
Helping Hand
Mine is above 100 madness.
mkk7781
Helping Hand
MartynaK
Beta Moderator
Beta Moderator
Hey @Robbie_R,
Thanks for pointing this out! If you're experiencing issues with battery life and high RAM usage, please report them through the Samsung Members app under “Beta Feedback.” This will help our development team investigate the problems more thoroughly :hand-with-index-and-middle-fingers-crossed:.
Robbie_R
Hotshot
I've reported both issues. Everyone else that's having the same issues do the same.
Robbie_R
Hotshot
Report it through the feedback section in the members app.
