Battery and overheating issues
(Topic created on: 03-03-2025 02:41 PM)
Erudite
Anyone experiencing these issues with beta 4/5? im on s24 ultra and I usually get 5hrs of sot minimum and im doing about the same amount of usage and somehow battery is really bad I also have felt some overheating more than usual
3 REPLIES 3
GooberCyn
Yea im also experiencing issues as my battery usually lasts the whole day but now I need to charge it way earlier than usual while using it the same amounf
mist2024
Not able to downgrade from one ui 7 beta 4 to ui 6 official via smart switch.
Showing no downgrade option
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Erudite,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
