Useless Battery usage tracking
(Topic created on: 23-03-2025 07:06 PM)
UnixM
Anyone know any tips to make the battery usage tracking actually useful.
Both in good guardians and normal settings, I can't see what's using battery with the screen off. Because of this I just have to accept the useless battery life as I can't make educated adjustments?
2 REPLIES 2
SRK-HD
Navigator
If you're on beta, there's nothing using your battery
The software just suck and in some devices, it's meant to drain the battery even on standby mode😂😂😂
AnnaMaz
Beta Moderator
Beta Moderator
Hello @UnixM,
Have you tried checking "battery usage since last charge" statistics? Hopefully it can help you make the adjustments to optimize battery life
Have a good day!
