Samsung Galaxy S8/S8 + problem: (Device Care) CPU overloading. Restart
(Topic created on: 11-04-2022 08:54 PM)
jay4jo
Hi I keep getting a message saying that apps are making my CPU to overload and i need to restart my phone it's only just started to happen. Is there anybody who knows what i can do to fix this thanks in advance jay.
33 REPLIES 33
Héctor Padilla
Same here, phone warming up, battery draining up very fast., restarting does nothing and we are unable to see which app is overloading CPU. Does anyone has been able to find a solution?
Joe Daou
I've been experiencing an issue since the month of July 2022 started
I changed nothing in my phone settings and applications, all is still the same as it was before, and no issues used to happen before. Battery was perfect
I go to sleep at 11 PM with my battery at 100%, no apps working, I used to wake up at 5 AM with th le battery still full
Now i wake up on daily basis with the battery dying, and a message from the device care saying:
Some apps or processes are overloading the system CPU, please restart the phone
Samsung team, what is happening?
Many other members are experiencing the same issue
A similar issue happened with iPhone users having old phones, so they buy new ones
#samsung-s8
olliehubb60
Pioneer
Try going to battery and device care and do a ram clear and if you have enhanced processing on the turn it of its been happening to me when I turned off enhanced processing it stopped and close any apps that are using more power when not ment should show you put app in deep sleep in battery and device care
olliehubb60
Pioneer
And turn on adaptive battery if already have it on ignore this post
Pugs1957
SuperStar
Can you post your battery stats here? Settings, battery and device care, battery and tap the graph so we can see what's eating your charge.
AntS
Hi all,
I’ve moved and merged some stuff to create this thread as it seems that this issue is affecting a few S8/S8+ users out there.
As Josh_S said in the similar S22 Ultra thread here, it’s best to send our software team error reports with log files for them to analyse. It might not be applicable for all folks in all countries (the team here are based in the UK & Ireland), but if you're able to send error reports with log files, please do so.
As soon as the issue occurs (within 15 minutes is best):
Samsung Members > Support > Send Feedback > Error Reports > [select error type] > choose frequency of issue, and write an accurate and good description (and attach any screenshots/pictures/videos showing the issue if you want/are able to) > tick ‘Send system log data’ > Send (the > icon on the top right).
(Or: Long-press the Samsung Members icon on the Apps screen, and select 'Error reports' from the dropdown menu, and follow the steps from there.)
Felipe ch
I'm getting the same message for about 3 weeks in my s 8 plus. Device care restarts it every day and it works for the rest of the day.
wakeylad
Hi felipe been getting this since july phone getting warm and draining battery ok after restart. Sending logs to support reckon its first time they have seen this problem. Anyway just removed Spotify App and problem disapeared. Hope this helps
wakeylad
Try removing spotify if you have it. Cleared my similar problem since july. Hope this helps
wakeylad
Try removing spotify if you have it cured my problem oveloading cpu
