Go to solution Solved
MY PHONE ISN'T CHARGING, I TRIED CHARGER PAD AND IT DOESN'T WORK
(Topic created on: 20-12-2022 10:38 PM)
WhiteKitten1
Navigator
Other Smartphones
WHAT DO I DO
Glenntech
Samsung Members Star ★
Other Smartphones
You don't say what phone you have.
So I take it plugging in the charger doesn't work.
By saying pad, I take it the phone has wireless charging.
What happens when you try charging?
Does anything show?
Is the phone turning on or is it flat?
Depends on the age of the phone, but calling Samsung Customer Support, you can book in a repair to get it assessed.
2 REPLIES 2
Glenntech
Other Smartphones
Does anything show?
WhiteKitten1
Navigator
Other Smartphones
I told you my phone in my last posts but don't worry my phone is charging again after 7 minutes
