20-01-2021 02:17 AM in
Other SmartphonesHello everyone, I was wondering if anyone had encountered a similar issue as me with their phone battery?
I have a dual SIM Samsung J6 (SM-J600FN/DS) which I bought off Amazon in Germany in May 2019.
I am very happy with the phone but as with all Smart Phones I have owned it is starting to play up within two years of owning it.
About three weeks ago I noticed that when charging the phone it was taking a lot longer to reach 100%. In the last week this has gotten far worse and will only actually increase charging when the phone is turned off. Then over twelve hours the charge will increase about twenty percent or so. If it is plugged in to a charger whilst the phone is turned on then the battery percentage will actually either not change at all or slowly DECREASE. If I am using the phone whilst it is turned on and plugged in then the battery level will begin to drop rapidly. If I use the phone as normal, not plugged in, then the battery decrease behaves as normal and drops as expected.
I have tried the following things already having checked online for some advice;
- Cleaned out the battery connection port on the phone
- Tried numerous different chargers, adaptors and cables
- Charged the phone from numerous different plugs in different buildings (even countries)
- Drained the battery to absolute zero and then recharged
- Downloaded a battery diagnostic app that said my battery was fine
- Went into a booting menu upon start-up and wiped the cache partition
- Went into some secret Samsung menu and turned the battery dump on/off
- Started the phone in safe-mode to see if it charged any differently
- Removed recently installed apps
None of the above had had any effect on the charging.
The only things I haven't tried yet are factory reset and I did see something about battery calibration although it didn't seem relevant to my issue.
Does anyone know what might be causing this and does anyone have a fix? If not then what would I need in terms of repair> A new battery or something else?
Thanks for the help!
20-01-2021 03:02 AM in
Other Smartphones20-01-2021 03:50 AM in
Other SmartphonesThanks for the reply SyLambert.
I don't usually use the phone whilst it is charging, but I thought I would include the oddity that the phone battery percentage decreases when this is done at the moment to see if that meant anything to anyone from a technical point of view.
As for using the correct charger, I have tried both the original charger and other chargers in order to check that the original one was not faulty. I believe by and large the theory/myth that you shouldn't use other chargers relates more to; the company wanting you to spend your money on their chargers; an excuse to easily void warranty; an effort to avoid people buying unsafe knock-off/dodgy chargers (ie: off the street, professing to be an original charger but in fact being a dodgy replica and therefore not conforming to safety and environment standards). Cheap, non-brand chargers that can still be purchased in high-street stores have always been in my experience fine although they may charge slowly due to lower ampage to err on the side of caution. By the by I have almost always been using the official charger with this phone anyway.
20-01-2021 04:53 AM in
Other Smartphones
