11-03-2021 12:38 PM
12-03-2021 07:40 AM
turn off your device. Plug it into the charger and then press volume up and power, keep them pressed and you'll boot into recovery, from that perform the wipe cache partition.
Have you turned off enhanced processing and turned on battery saver?
12-03-2021 07:48 AM
battery estimation is not something you should look at, they are stats based on the previous week and you can easily get more than that or less in base of how you use the phone.
Just use the phone as normal and report the screen on hours this evening
12-03-2021 08:24 AM
12-03-2021 08:24 AM
12-03-2021 08:42 AM
12-03-2021 09:27 AM
12-03-2021 03:26 PM
12-03-2021 08:32 PM
try after plugging it in to hold volume up first and then once you are pressing volume up press the power button and keep both pressed
12-03-2021 08:35 PM
the battery life you get should be about right, don't know where you are loosing around an hour however.
Don't worry about having to put the phone in power saver, it just limits the spikes of the cpu clock and it is something you will not notice in normal use.
Try changing your browser from chrome to internet samsung it is much more power efficient as a browser and lets you to have the full screen show the pages without the bars
Also at which brightness you usually run your device? If you are going full throttle on it it may be the determining factor of your consumption.
Are you running at 120 or 60 hz mode or adaptive?
13-03-2021 12:01 AM
