Water from washing machine filter
(Topic created on: 03-04-2023 09:23 AM)
Hall1
Just cleaned filter for the first time in washing machine. I drained hose first then took the filter out. When I opened the filter lots of water came out. It didn’t happen on the instruction video or mention it so wasn’t expecting this to happen. Is it a problem?
1 REPLY 1
AndrewL
@Hall1: Please can you confirm the model number of your washing machine? This can be found on the sticker on the inside of the door or drum.
When cleaning the drain pump filter, water should not spill out of the filter housing itself if you have drained it successfully. If you take a look at the guide below, did you make sure to follow the steps laid out here before removing the filter?
https://www.samsung.com/uk/support/home-appliances/how-do-i-clean-the-debris-filter-in-my-front-load...
