Washing machine WW90T534DAW makes rubbing and squeaking noise when turning
(Topic created on: 04-09-2023 08:00 PM)
Anna186
Hi,
The machine is making a rubbing noise when I turn the drum by hand (video attached). Before it was making a banging noise for some time. It was levelled and not overloaded.
Can you advise?
7 REPLIES 7
ChrisM
SuperStar
Hi @Anna186
Is this still happening? Does the drum make a noise when in operation?
This could be the bearing seal wearing off - I'm facing the same problem on my machine. Definitely not ideal
PaulM1
Hi, @Anna186. I highly recommend consulting the thread below:
https://eu.community.samsung.com/t5/home-appliances/bearings-failing-already-on-2022-bespoke-ai-wash...
It's not clear whether you're experiencing any issues with noise or the function of your washing machine while it's in operation.
As mentioned within the linked thread, it'd possible you'll need to liaise with one of our Support Teams who'll guide you on the next steps.
Please let us know how it goes.
Anna186
Hi @ChrisM , yes, the same sound takes place when the machine is in operation. I noticed the sound for the first time when I started a cycle and the drum was turning to evaluate the load. I stopped the machine right away as didn't want further damage if there was any, didn't want to risk...
Hi, I posted about this all and then just stayed off this app for a while. How's your machine now? I've requested a repair for my model now since it's getting worse.
Anna186
Hi, I called out a Samsung engineer as the machine was still on the warranty. 2 week after he came and found the issue - the belt was stretched, so when the drum was passing the stretched section of the rubber band, it was making that noise. The belt was replaced and the issue was resolved - for free as still on warranty.
 I hope your machine will be repaired quickly and easily!
Anna186
