Samsung RB31FDRNDSA compressor noise
(Topic created on: 10-09-2017 09:41 PM)
shuff01
Hi there,
I purchased a Samsung RB31FDRNDSA a week a go that was delivered to me on Thursday 7th September. The delivery driver advised me that I should let the fridge stand for 4 hours before switching on to let the gases settle. To air on the side of caution I let the fridge stand till the following morning, some 18 hours.
When I switched the new fridge on I was surprised by the noise the compressor makes, I thought maybe this is due to heavy loads on the compressor as it tries to bring the internal temps of the fridge and freezer down.
Three days on and the noise is still as loud, thankfully the compressor is no longer running continuously but when it fire up the noise is quite bad.
There is a high pitched electrical noise and also a noise from inside the compressor that sounds like a defective bearing or something.
I have of course checked that the fridge is level and that nothing is fouling at the rear of the fridge. Surely this noise is not normal? How can a product costing this much claiming to be the next best greatest thing be more noisy than the failing Indesit it hs replaced????
31 REPLIES 31
Anonymous User
Not applicable
Finally getting support Mind Out! Samsung has removed my product from my account 3 times now seems veeery I'll manored to remover product registration from a customer definitely effecting my opinion of samdung
Anonymous User
Not applicable
https://youtu.be/EcD63CFswe8   here is a video of the fault with the audio set up to 450% so you can hear it through the microphone as the devices don't do it justice I'm living with physical damage to my ear because they wont take me seriously this is atrocious
now imagine that 24/7  good luck
