Samsung emergency hose pipe inside hole
(Topic created on: 23-03-2023 02:44 PM)
Syed33
Home Appliances
Pls advise i
How i can pull out the pipe really can't afford handyman
7 REPLIES 7
andy_in_ireland
Helping Hand
Home Appliances
you may be able to get to the emergency pipe from underneath the machine. To do this you will have to pull the whole machine out of its space , then gently (with the help of the other person) tilt the machine back, (with the other person holding the machine) - take care not to crush the pipes at the back of the washing machine.
To see all the pipes underneath the washing machine, depending on your washing machine model, you may need to remove a black plastic corrugated cover from underneath the machine to see the pipes.
Once you see the emergency drain pipe, feed it through into the right space behind the pump filter door .
Good Luck
Raza9
Home Appliances
Thank you I appreciate this...I thought there might ve something simpler but I will have try this
andy_in_ireland
Helping Hand
Home Appliances
I don't think so , sorry
Raza9
Home Appliances
Hi the model is WD906U4SA by the way. An eco bubble washing machine. Will be trying the steps today with husband.....feeling nervous....Will keep you posted
andy_in_ireland
Helping Hand
Home Appliances
good luck i hope you get on ok doing it, i'm sure you will
Raza9
Home Appliances
Well we have the corrugated plastic cover which came off after struggling to find the pipe. My husband try to locate pipe but has fed thru the upper hole instead. It was 2 to 3 hours effort with his hands all bruised up. The cover we don't know how to put back on so left it out completely and hope that the drain tube being out in the upper hole is ok...it was a sheer pain. But we hope its done the trick . What do you think
andy_in_ireland
Helping Hand
Home Appliances
sorry to hear about the bruised hand and how long it took to do. I really thing the pipe should come out of the bottom hole but see how you get on
