Hi there,
I located the Emergency Drain Hose to clean it out together with the filter however, I can't seem to pull it out far enough like how it is advise on the following link:
Can you please advise if it is meant to be like that? The water ended up dripping everywhere and I can't seem to clear it out effectively.
Any help or advice is much appreciated. Thank you so much!
Hi ChrisM,
Yes, I am still facing the same issue. Please help. Thank you!
@mable: Please can you confirm the model number of your machine? Are there any error codes visible on the display?
