Fridge freezer beeping when I open door
(Topic created on: 20-03-2024 10:59 AM)
Beepingfridge
My Samsung rb29fwrndss fridge-freezer has started beeping when I open the fridge door. It just makes a single beep most times (but not every time) I open the door.
The fridge is keeping food cool enough (measured temp as 1.9C, though the thermometer isn't the most accurate) and the stuff in the freezer is still frozen. I know that this model has an alarm if I leave the fridge door open too long, but this is a different sounding beep and just a single beep rather than an alarm. The temperature selection interface at the top of the fridge isn't flashing or anything.
Any ideas? I've checked the doors are closing or, and tried turning it off then on again at the mains. I've checked the manual , but can't see this mentioned
5 REPLIES 5
TechMyBox
Maybe u have it open to long
Robin999
Samsung Members Star ★
Can you check out this thread
https://eu.community.samsung.com/t5/home-appliances/fridge-freezer-keeps-beeping/td-p/1485290
Some saying it's a problem with wiring and some about moisture build up. If your appliance is still under warranty then please seek help from Samsung before attempting any unauthorised repair.
Beepingfridge
Thanks. It sounds like my problem is a bit different to that thread - my fridge just beeps once at the moment I open the door, and is otherwise silent. I'll try cleaning the door seal in case that is causing problems. Otherwise, I think I'll need to check if my fridge is still under warranty.
Anything else DIY to try first?
Robin999
The thread suggested that the frayed or cut wires were causing the erratic beep each time the door was opened and closed. Yes, please check your warranty status first!
Gregk64
Navigator
I agree, when produce is being put in the fridge after shopping it beeps continuously as warning that the door is open too long and tempature is dropping.
