Eco bubble fuse in plug blown and keeps blown after replaced
(Topic created on: 23-10-2024 08:04 AM)
I have this problem too (1)
simbosimbo
Hi, I have had my Eco bubble washing machine around 12 months and last night it blew the fuse mid cycle. i have since replaced it twice and each time it very quickly blows again leaving me with a load of washing still locked int he drum and the machine itself unusable.
any ideas what i need to do next?
Many thanks
3 REPLIES 3
andy_in_ireland
Troubleshooter
Many thanks
When you have replaced the fuse now does it blow as soon as you plug in or half way through a wash instead?
simbosimbo
Hi it blows as soon as I plug it back in
andy_in_ireland
Troubleshooter
ah right thanks for the reply, sounds like some kind of electrical short circuit in the machine then - could be something as simple as the filter capacitor shorting out or a more serious short somewhere inside the machine - theres not much you can do I dont think apart from getting a washing machine engineer out . I dont think the Samsungs have an emergency door release outside of the machine (ie behind the door for the pump filter) if they did and the water was not up to the glass of the door you could at least emergency release the door open and get your garments out.
