Door peg replacement on SAMSUNG Series 5 DV90TA040AE/EU 9 Heat Pump Tumble Dryer
(Topic created on: 02-03-2024 04:37 PM)
LondonBlues
Is it possible to replace this door peg part on the SAMSUNG Series 5 DV90TA040AE/EU (9 kg Heat Pump Tumble Dryer - White)? It is relatively new (a couple of months) and the door doesn't register as closed because the small plastic limb has snapped off (Pictures attached). Can the part be replaced or repaired or does the whole door need replacement?
1 REPLY 1
Members_vsAVLWt
Did you find any solution? I have the same issue and can’t find any solution online. Thanks
