Does Bespoke Refrigerator have water filter bypass?
(Topic created on: 23-11-2022 03:25 PM)
bigdogdan2
Does Bespoke Refrigerators have water filter bypass?  I would like to use my RO water system for the water and ice in the refrigerator.
Thanks!!
5 REPLIES 5
Fd1324sfd
You should be able to remove the water filter once you have primed the system the filter cartridge area has a bypass that once the filter is removed it’s supposed to engage the bypass when you remove the filter
bigdogdan2
Hi Fd1324sfd,
I have the Samsung Bespoke 4-door French door Fridge.  And I thought the same thing you mentioned, but when I remove the filter, water starts spraying out the hole of where the filter is suppose to be.  Is there a way to manually engage the bypass filter?
Purvaja
I would like to know what the answer is to the above question because I also want to bypass the water filter since our main line of water is already filtered for the entire house.
The Griffins
I would also like to know please.
Fd1324sfd
There is a built in bypass all you have to do is remove the filter and it will be good to go the app will annoy you a few times but will work without the filter it has one built in
