Broken plastic part on inside of machine door. Any advise?
(Topic created on: 03-04-2022 05:41 PM)
Darren Beaumont
I have a Samsung Eco Bubble washing machine model WW10H9600EW
Recently I did a wash load and on emptying the washer found a small piece of plastic in my laundry. On closer inspection I can see that type plastic has broken off from the inside front top left of the machine between the drum and the door seal. My best guess is that this helps guide water into the drum.
Can anyone advise what this part is and the impact of it having broken off?
I’m curious if the machine will still perform as normal without it, or else if this is a replaceable part I can get an engineer out to fix.
Thanks in advance for any insights.
Darren
2 REPLIES 2
CarlH
Hi Darren. It might be best if an engineer inspected your washing machine. Take a look at this link to find the closest Service Centre in your area: https://www.samsung.com/uk/support/service-centre/
TygaS
hi, do you have fix the problem ?
i have the same....
Thanks
