Flip 5 max battery charge changed to 80%
(Topic created on: 29-03-2024 12:54 PM)
FudgeMonkey
Anyone know how to set this back to 85%? Updated today and now the charge, to protect battery life, has been reduced 😤
4 REPLIES 4
UNKNOWNUSERNAME
Samsung Members Star ★
hi, you can access this via settings>battery>battery protection then select what u want from there (if on ui 6.1)
MPNI2025
FudgeMonkey
You can't change the "maximum" one it's fixed at 80.
UNKNOWNUSERNAME
I didnt say u can change the maximum, i said you can change to the likes of 95 or adaptive, or even turn it off. You basically just answered your own question.
MPNI2025
Xenon2000
95% is not an option. Only 100% and 80%. I too want my 85% back.
