19-02-2025 02:41 PM - last edited 23-02-2025 07:17 PM
Solved! Go to Solution.
18-05-2025 06:33 AM
I'm having the same issue. None of the suggested solutions work.I need to have a reliable timer!
25-05-2025 07:12 AM
Hi guys, so I've been looking this timer not sounding problem online, and that's how I got to this page, and since it didn't seem that anyone has a working solutions yet so far here, I would share what just worked for me.
So, in my case, turned out that I had the "clock" app put under "sleeping apps". So as a result, after setting up timer and turning off the screen, sleeping apps would be prevented from running in background, and it would not sound when the time was up. So, I removed the "clock" app from the "sleeping apps" and the timer has been sounding all the time since.
(Go to: Settings - Device Care - Battery - Background usage limits - ... then check all sleeping/deep sleeping apps, remove "clock" app from sleeping/deep sleeping)
Also, I did some more to make sure it won't sleep in background, by setting the "clock" app battery usage to "unrestricted" to make sure it can run on background.
(Go to : Settings - Apps - Clock - Battery - Unrestricted)
Source: my phone, Samsung Galaxy S24, One UI 7.0
Hope this helps!
Y
26-06-2025 07:48 PM - last edited 26-06-2025 07:49 PM
Just recently, this is happening to my S20Fe. All of a sudden, I noticed my timer not going off. It stops but doesnt go off. I tried then it will go off at random time. But alarms are working fine. Already tried and checked details mentioned above, even tried dowloading a different app. But the same issue.
27-06-2025 11:10 PM
I have the same problem no Audible alarm for my timer. Come on Samsung please fix this issue!
