Samsung S24 Ultra overheating and draining battery while using camera
(Topic created on: 21-02-2024 06:03 PM)
Bryan27
Hi guys, i recently bought a S24U on pre-order but am having thermal and battery issues with it.
Every time i launch the camera the phone gets really hot and i lose around 2% battery every minute. I charged the phone to a 100% and tested the camera for nearly 6mins, the battery dropped to 88%.
Am using the phone on UHD and in standard mode for performance. The OS and the apps are up to date.
I tried putting it in light mode hoping to see a difference but in vain, nothing changed. Even on while doing a video call i can see the battery just draining away and the phone gets annoyingly hot. I would appreciate if someone can help me out on this. Thanks
33 REPLIES 33
Bryan27
I don't have any apps open when i use camera, i even put some to sleep. Still doesn't change a thing.
GoanGeek
Samsung Members Star ★
I did notice crazy heating when shooting in 4k as well at a party.
Haven't tried again recently.
I just put it down to other background apps at that time.
It did cool quickly as well.
Something to look out for.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
Star_girl
My phone was overheating as well in the first 2 days of use but now it gets warm only when I use the camera and when I charge it from the powerbank, probably a little bit when I do WhatsApp videocalls, but it's not so perceptible.
Bryan27
okay, yours is probably pretty normal i guess 4k do use a lot of that processing.
The thing is, even with normal shots, like am taking some pictures or am just trying to zoom in and out, it starts heating like crazy. It does take a min to cooldown yeah.
Bryan27
Oh okay.. warm is acceptable, but mine gets to an annoying level of heating. I really hope its a software issue which could be fixed in the future. If its hardware i'll be out of luck!
Star_girl
Yes, I am sorry to hear your phone is overheating. Be mindful of the cool down period in case it's faulty. Keep us updated on how it's going.
Bryan27
I will keep an eye out on that. Thank you for the help. Really appreciate it.
GoanGeek
Out of curiosity. Did you do smarthswitch transfer?
Bryan27
Yes i did from an iphone 13pro.
GoanGeek
My experience with smartswtich that most people who have issues are those who did a smarthswitch.
I would recommend backup you contacts, messages , photos etc in Google One.
Factory Reset your phone and don't restore apps or settings. Restore the rest and manually install apps as and when needed.
I know it's a bit extreme but it's worked for me all these years.
I would suggest only do it if you have other issues as well.
If not check YouTube on how to WIPE CACHE the phone.
