YouTube battery drain & overheating issues
(Topic created on: 30-10-2024 07:15 AM)
pagagagamate
Pathfinder
The YouTube app causes my Samsung phone to overheat after a random amount of time. Since I can’t uninstall and reinstall the app, clearing the cache and storage or force stopping it only provides a temporary fix. This issue seems to be specific to the YouTube app, as it only started happening in the past few weeks. As a YouTube Premium subscriber, this makes the app nearly unusable.
On Reddit you can see a lot of similar posts.
63 REPLIES 63
pagagagamate
Pathfinder
Didn't manage to test it much recently. But I felt that the latest update helped a little bit with the issue. But yeah - it's embarrassing. Samsung support told me to contact YouTube - but there's no way to contact them directly.
Goldenglove85
Navigator
Turning battery saving on on these phones do not work. Youtube is killing these phones and youtube only! I've written youtube and many other people have as well and youtube just sends you to their tip center for tips like, "turn screen brightness down, lower resolution " and so on. Well I've got all settings lowered and it still drains the battery and and phone gets so hot! This is proof youtube is not planning to fix this issue nor is samsung! Only youtube is doing this! Only thing that will maybe happen is if we all quit using stupid youtube. Then maybe youtube will fix the problem.  Start using alternative sites. Maybe then youtube will maybe care
Goldenglove85
Navigator
Goldenglove85
Navigator
Mine is not set for HD. Everything is set at low settings. It still happens.  This isn't the issue.
Goldenglove85
Navigator
No that's not the same at all. More like you'd have to cut your ac off because it sucks power from your 500hp engine.
Goldenglove85
Navigator
Goldenglove85
Navigator
So youtube has been sent the problem? They know it's an issue now? Just wanting to clarify.
Goldenglove85
Navigator
Olivia W
I keep having this issue too and have had this issue for years on various phones. It's a Youtube app issue. Google is clearly uninterested in fixing it.
pagagagamate
Pathfinder
Yes - very frustrating indeed 😞
