14-02-2023 05:32 AM
Solved! Go to Solution.
20-02-2023 09:42 PM
I am having the same issue and am also using lens protectors. The ones made by Spigen to be precise.
So I'm not sure whether the issue is the protector over the actual cameras or the one over the laser focus but I might pop them off and see.
20-02-2023 09:59 PM
Yep, that fixed it. So I don't know if there's a software update that's going to resolve this but for now I'll have to use the phone without the lens protectors. I have also used them before without issues on other phones. Let's hope this is just an issue since the phone just came out.
20-02-2023 10:01 PM
20-02-2023 10:16 PM
It would have been more scientific to do so, but I didn't. I figured as there's no issue with focus in any other situation the laser probably wasn't the issue, but I didn't check them one at a time. I just took them all off and now it works.
Let me know if you try just doing the laser. 👍
20-02-2023 10:38 PM
20-02-2023 11:09 PM
20-02-2023 11:19 PM
Before removing the lens protectors I tried using the phone camera in a dimly lit room at home. I changed resolutions, camera modes (including night mode), and tried to force it to focus on objects and throughout it remained blurry.
After removing the lens protectors I went to the same spot and focus was spot on as I replicated the process.
20-02-2023 11:28 PM
21-02-2023 12:13 AM
22-02-2023 10:24 PM
