S22 ultra camera issue with led bulbs
(Topic created on: 29-04-2022 01:36 AM)
DragonWolf5589
Pathfinder
Does anyone else have issue where the camera refresh rate is very poor so led lights flicker very badly to point if I'm indoors with any led lights (which face is is everywhere indoors) it takes awful pictures.. Like THIS bad in the photo. Does it in expert raw as well. Unless I REALLY fiddle with the settings.
Oddly the Samsung members diagnostic has no fault, and also Samsung in twitter said to try *#0*# and text mega cam and show a screenshot. Again.. No lines or issues. They said try to do a reset as they can't see issue with the service tests meaning its likely a software bug. But a reset has not done anything (by reset they mean camera app settings reset)
Anyone else having these poor issues? As now I wish I didn't post my s20 plus back but had to due to being trade in.
(note x10 zoom has NO issues. The 0.6x does show similar but not AS visible)
It's also worse if I pan the camera side to side but can't show that unless I screen record. It does it VERY slightly in videos too but photos are just so so bad!
(1tb s22 ultra, UK)
_________________________________________________________________
Main device: Galaxy 1TB S22 ultra
Other Devices: Galaxy watch 4
Old devices I miss: s20+
11 REPLIES 11
Krisalex79
Helping Hand
This is a led bulb, image is made with expert raw app. it does not flicker. try a different make and model led. maybe ot is led bulb fault one example if there is no smoothing capacitors on the bulb led driver circuit.
The FACT that i PRETEND to believe you, DOES NOT mean i actually believe you.
Krisalex79
Helping Hand
 This is a led bulb, image is made with regular camera app. it does not flicker. try a different make and model led bulb. maybe it is led bulb fault - one example if there is no smoothing capacitors on the bulb led driver circuit. another example is using just diodes not in a rectifier configuration instead of a proper full bridge rectifier (i know the full bridge rectifier is based on a 4 diodes made to pint in the same direction to convert ac to dc)
