Random AUDIO distortion over USB-C earphones S22+ HELP
(Topic created on: 07-04-2022 10:00 PM)
Dreadish
Navigator
When im listening to music or watching videos over AKG USB-C original Samsung earphones, sound ocasionaly after a while audio started getting distorted -  Its totaly random. It happens randomly, but when it starts, its goes on and on every few seconds. Pause the video/music and resume,  makes it go away, but starts again in few seconds. when this happened, i disconnected the earphones to see if it will continue over speakers, but it didnt. Over speakers plays no problem. Then i  tried another original AKG samsung earphones,  and it was again distorted every few seconds. Earphones are not the problem-they are all original, tried 3 of em and they are not the cause.
Fact 1: audio gets distorted, and when it does, it dosent stop untill reboot.
Fact 2: audio gets distorted  ONLY when i have connected USB TYPE C  earphones (all original from Samsung)
Fact 3: audio plays normal on speakers on every volume
Fact 4: i booted in safe mode, also was playing normal with no  distortion.
Fact 5: i  tried with or without DOLBY ATMOS-didnt fixed distortion, was still distorted
After i reboot in safe mode, it played  normal again, now after few hours , didnt came back. i rebooted back into normal mode, and issue atm didnt returned. but it will, since last time it did.
Im trying to  figure out what causes it. (hardware or software).??
I have April update firmware and I already did factory reset after updating. Didnt helped. Since its random, and it happens only when using earphones, maybe usb-C need too get firmware fix? I read old s21 forums, some people got firmware updates for usb-c connector.
Maybe April,s Firmware S906BXXU1AVCJ did something to audio driver in S22+??? and need to be fixed in next updates?
Any help would be apreciated. What else can i try when audio distorsion comes back?
Samsung,  FIX this!!!! (or im thinking returning the device)
84 REPLIES 84
Dreadish
Navigator
Ok. I have tested new update with wired usb c akg earphones and the problem still exist. Got distortion over watching a movie or listening music. Exacly same audio distortion as before second april,s update. What the hell samsung?  Usb setting" app is still on version 1 as well. U need too adress this issue!!!
Dreadish
Navigator
Besides distortion also equalizer in samsung settings  or even dolby atmos on the settings dosent even work or effect the audio over usb-c connected earbuds. Same audio no matter what i press dolby on or off. No effect too audio, while  over bluetooth earbuds atmos works but its not working over wired usb c earbuds . Omg this is worse flagship i had in years. If this shi...t wont be fixed soon im gonna return the device demanding money back .
VincentM2
I think I might know the issue. I began by plugging in a wired speaker to listen to the clipping and audio distortion. To my surprise there was nothing...I used the speaker over 2 days and could not reproduce either issue. I concluded that the inline mic was causing the issue. There should be perfect sound isolation when the mic is not in use basically not on a call. But due to manufacturing issues this may not be the case. I specifically referring to the distortion. From my limited knowledge of the situation I think ambient frequencies are leaking into the cable from the condenser or inline termination connection. It travels to the input of the ADC function in the DAC circuitry and because there is no call present it wraps around into DAC function of the DAC circuitry and adds to the flow of digital signals that playing music presents. This causes distortion which can be heard in the headphones. I had a pair of £15 old sony earphones with an inline mic and was able to reproduce the issue. So I decided to purchase a cheap earphone on amazon without an inline mic (jvc explosive extreme cost £15). Both issues have now disappeared...this is only a workaround as I have to put my phone on vibrate when using these earphones so I don't miss a call. With regard to the clipping that was the result of 3.5mm connector...the gold plating had worn away and the tip and ring portions were also worn. The DACs in usb headphones/dongles are of low quality so any noise introduction can overload their circuitry. It's not to be compared to DACs found in DAPs. For me it seems to be hardware related as I mentioned before if the inline mic is not perfectly isolated when not in operation ambient noise can leak through the hole. I must point out this my subjective opinion but I hope this helps going forward in resolving your issue.
VincentM2
One correction, I don't have to put my phone on vibrate as I can hear an incoming call through the earphones. The inconvenience will be disconnecting the earphones + dongle to answer the call.
Dreadish
Navigator
This is very interesting, about inline mic. When i have a chance ill test it without the ones without  mic-thanks for your very detailed insight M2Vincent. I have 3,5 to usb-c original Samsung,s dongle. Either way, distortion  should be fixed via software (i remmember booting into safe mode, it was gone at once). Wired audio is still better then any bluetooth one. Samsung should fix this by now!!!
VincentM2
Interesting what you said about safe mode....if my suspicions are correct, it's not an issue with the phone per say...more like the earphone. For me, once the inline mic is out of the equation then no distortion occurs. By this I am not saying all inline mics present an issue just the defective ones whether that is through wear and tear or manufacturing defects. Once unwanted noise enters the circuit then feedback occurs which comes from the DAC in the earphone/dongle.
Dreadish
Navigator
Martin,  we already have original Samsung earbuds. Myself i have Samsung AKG original usb earbuds and the ones with  3,5 with dongle. 4 of them :winking-face: Maybe that "safe mode" was coincidence. I did tried it only once. Next time, ill try use dongle with  earbuds with no mic,  and test i your theory Vincent.
Dreadish
Navigator
God dammit, yesterday i was trying to reproduce the issue and didnt appear. What the hell is the reason  that trigers it. I wonder.....
VincentM2
For me the issue is now somewhat resolved. Since I have been using the non-inline mic connection I .have had no issues. The music plays as expected. I can certainly hear the effect of the sound enhancement settings (i.e. dolby atmos, uhq upscaler)....I still believe the inline mic is causing your issues.
NzBeenie
Moreover, the equalizer and Dolby Atmos settings on Samsung's settings do not function or affect audio over USB-C connected earbuds. The sound does not differ if I turn Dolby on or off. Atmos does not work with wired USB C earphones but it does work with Bluetooth earphones. I have never owned a worse flagship in a long time. The device will be returned and a refund requested if this disgusting error is not fixed soon.
